Page 2 of 3
Re: MUGELLO 225
Posted: Fri Jan 13, 2012 12:57 pm
by Beanhead
thats the one!!!
i never drop his name tho,he always said to keep my settings a close kept secret,so i have obliged.lol
Re: MUGELLO 225
Posted: Fri Jan 13, 2012 1:20 pm
by Bilko
I agree, my Stage 5 Muggy 225 is a flyer. I think I should reconsider getting rid of it.
Re: MUGELLO 225
Posted: Fri Jan 13, 2012 6:43 pm
by shocky
Beanhead wrote:mine has a 28mm carb and a 48mm ancilotti clubman,mines been measured at 83 going into the wind and slight uphill.
WOW wouldnt that be revving at about 8500rpm, as far as im aware the pipes dont rev that far and if they do they have been modified. and at those revs the tourque curve drops right off :?: and thats were incline and wind would have its most effect .... just asking like
Re: MUGELLO 225
Posted: Fri Jan 13, 2012 7:39 pm
by gerryjunior
Christ :o :o if it'll do that down a big hill with me lying flat on the seat ill be happy..looking at the port's they look standardish size wise i thought about 70 ,, thanks for the reply..ill wait and see.
Re: MUGELLO 225
Posted: Sat Jan 14, 2012 12:19 am
by cezeta
mine is a similar set up with standard gp200 gearing and is flat out at 65mph for me to get to 83mph i would need to be reving close to 9000 rpm
out of the box expect 12 - 14 bhp on a 58 mm stroke crank
Re: MUGELLO 225
Posted: Sat Jan 14, 2012 4:10 pm
by corrado
cezeta wrote:
mine is a similar set up with standard gp200 gearing and is flat out at 65mph for me to get to 83mph i would need to be Jimmy riding over the White Cliffs.
Mine's the same too. :D
Re: MUGELLO 225
Posted: Sat Jan 14, 2012 6:15 pm
by ktmh5
Same here, Mugello 225, 30mm PHBH, GP 200 box 18/47, Taffspeed Mk4, 11 stone rider. Sits at 65, 70-75 tops in good conditions.
Rich'
Re: MUGELLO 225
Posted: Thu Jan 19, 2012 9:23 am
by Beanhead
cant see why youre all getting lower speeds than me,was out on it again at weekend,same again, 80 plus.
got no rev counter,so dont know what revs i'm at,but like i said it's been measured on tw@ nav and a 200 auto vep.
Pity Dr Booth aint on here,he could vouch for those speeds too.
Re: MUGELLO 225
Posted: Thu Jan 19, 2012 9:24 am
by Beanhead
oh,just to add, my speedo reads about 9-10 mph out,and it goes off the clock,reading 90
Re: MUGELLO 225
Posted: Thu Jan 19, 2012 9:45 am
by Special X
As standard the 225 Mugello is a bit lame due to trf timing of 117/118 degrees. Increase the trf timing to 123/124 and they are good. Fitting a 60mm crank will lift the trf timing to an acceptable level without cutting the barrel
