front disc diameter
Yes mate, although with that calliper it's a little close to the rim, so I fitted that setup with a Grimeca calliper and used the SIP calliper with a 200mm disc
tonydevon
Main scooter: '71 GP125
thanks for the help guys, bolted the 150mm in place and it looked silly, will use that on the back, got 220mm disc arriving tomoro.
tonydevon wrote:thanks for the help guys, bolted the 150mm in place and it looked silly, will use that on the back, got 220mm disc arriving tomoro.
It gets a bit tight to the rim on mine, I use the Vespa Grimeca which clears, mind you I'm sure you could find a way round it if your building your own ;)
tonydevon
thanks, my disc sits quite far out, had to put the wheel in the lathe and take 3mm off the hub, with the wheel central in the forks, the disc just misses the forks by about 1mm now :)
got small brembo calipers for front and rear
