Page 2 of 2
Re: GP crank with Yamaha conrod
Posted: Sat Dec 03, 2011 1:59 am
by Lamaddict
soullad wrote:
Lamaddict wrote:I've had 2 of these done no grinding or shimming. The only thing to watch out for is it makes the crank slightly wider so check if you need an extra mag flange gasket, I never have. Both were done by Dave at Frontline (old motorbike shop), South Bank, M'bro. Dave does lots of work for local lads on Lambrettas and really knows his stuff.
So, he doesn't fit any big end thrust washers?
No he doesn't. I asked him about it and he said Lambretta's wouldn't need them.
Both cranks have been SIL ones and with the beautifully engineered yam rod they look great.
Posted: Mon Dec 05, 2011 8:57 pm
by Supereibar
Mine touched the crankcase when rotating, so I had to trim the back of the conrod by a couple of thous. Other than that I just needed an extra mag flange gasket for mine. The rest was all fine.
J.
Posted: Mon Dec 05, 2011 10:04 pm
by boxofbits
Any good for a rb 20 this crank conversion !!
Posted: Mon Dec 05, 2011 11:16 pm
by carlos fandango
boxofbits wrote:Any good for a rb 20 this crank conversion !!
Ive just done one for my RB20. Sil crank and a yam RD400 rod 115mm.
The std rod should be a TV 116mm, so the barrel will need 1mm taking off the base. :D
Russ
Posted: Tue Dec 06, 2011 2:04 am
by Supereibar
Russ, mine doesn't have any skim done to the base of the cylinder. Its more a matter of modifying the head I think.
Best,
J.
Posted: Tue Dec 06, 2011 7:13 pm
by carlos fandango
Is it a RB20 Jaime ?
The RB20 uses a TV rod 116mm, so if you use a shorter rod, 115mm the piston at TDC will be 1mm lower and the port timings will be
different.
You could modify the head to take up the 1mm difference :? but the timings will still be different to std.
Russ
Posted: Tue Dec 06, 2011 7:31 pm
by RICSPEED
carlos fandango wrote:You could modify the head
resesing the head is not a bad idea
