Page 2 of 8
Re: YZ250 conversion
Posted: Fri Nov 18, 2011 2:59 am
by Chris CSPE
With the room that it has above the barrel will it be fitted with a down draft carb straight above the inlet or a long manifold and a carb. The down draft would be better for performance and less work.
Posted: Fri Nov 18, 2011 3:08 am
by tony
drew2 wrote:cheers mark,will do.
this is the new engine bracket rocho has machined to mount the engine,the mark
is where the bracket will be cut out for the carb
That is neat.
Posted: Fri Nov 18, 2011 1:26 pm
by RICSPEED
Chris CSPE wrote:With the room that it has above the barrel will it be fitted with a down draft carb straight above the inlet or a long manifold and a carb. The down draft would be better for performance and less work.
perhaps one like the dac bike used ??
Posted: Fri Nov 18, 2011 6:13 pm
by drew2
the engine bracket on the engine showing the cut out for the carb,
Posted: Fri Nov 18, 2011 6:48 pm
by tonydevon
so long as your happy, but slugs in my opinion and experience should be hollow, similar wall thickness to the tube your joining, and ideally about 1.5 times the diameter in length
some nice work going on there, I look forward to seeing more of it
Posted: Fri Nov 18, 2011 8:38 pm
by rocho68
tonydevon wrote:so long as your happy, but slugs in my opinion and experience should be hollow, similar wall thickness to the tube your joining, and ideally about 1.5 times the diameter in length
Hi tony ,yes its hollow and the same thickness as the tube
Cheers lee
Posted: Sat Nov 19, 2011 9:35 am
by willwander
drew2 wrote:
How does it attach to the rear part of the frame?
Posted: Sat Nov 19, 2011 3:16 pm
by RICSPEED
think it was mentioned in an earlier thread that the was to be some mono shock arrangement like the cutdown bullet /rough diamond etc
Posted: Sat Nov 19, 2011 4:00 pm
by drew2
frame is now ready to be cut
Posted: Sat Nov 19, 2011 4:22 pm
by RICSPEED
chop chop ..
