Page 2 of 2
Re: tx200 flywheel
Posted: Sat Oct 15, 2011 3:25 pm
by Danger
rite is this an easy fix or can it be fixed , or who can do this
Re: tx200 flywheel
Posted: Wed Oct 19, 2011 12:01 pm
by Danger
help plz
Re: tx200 flywheel
Posted: Sun Oct 23, 2011 6:47 pm
by wack 63
I've seen tight flywheels before and it's usually caused when the crank is twisted causing the flywheel to rub on the casing dust lip and the pole laminates,so have a good look at these areas which you could colour with a marker then run the motor and remove the flywheel to check.
Re: tx200 flywheel
Posted: Tue Oct 25, 2011 8:01 pm
by Danger
thanks wack , i wont get my hands on the scooter again until after i get back from bridlington , but i will defo give what you said a try really need this sorted thanks again an will post my findings
