Page 2 of 2
Re: Sprockets & Gearing issues
Posted: Wed Oct 12, 2011 10:18 pm
by jefo1970
Right I'm with ya now, thought you had changed the box over!
So if your now running 18/47 (5.2) I would say your about where you want to be, you have come down from 6.1 final drive! A 175cc top end with a Clubman style pipe set up is around 5.2 so you should be sorted mate.
Good luck.
Posted: Thu Oct 13, 2011 12:55 pm
by simplex
jefo1970 wrote:Right I'm with ya now, thought you had changed the box over!
Good luck.
Cheers.. i will try adjusting the jetting a little and see where it gets me.. failing that i will try coming down on either sprocket .. or both..
Posted: Thu Oct 13, 2011 1:27 pm
by soullad
Be wary of downjetting thou mate, esp if it was revving out cleanly when you had it at 6.1 final drive. I'd hate for you to damage the top end for no reason. It won't cost you 'owt to post up your jetting spec first?
