Page 2 of 2
Re: Front Dampers
Posted: Sun Oct 16, 2011 6:10 pm
by goldeneye
forgot to say, he got the uprated ones, and they were 40 quid a pair.
Re: Front Dampers
Posted: Thu Dec 01, 2011 12:14 am
by Spud
Does anyone know if these are the standard or lowered type?
Re: Front Dampers
Posted: Mon Dec 05, 2011 9:27 pm
by grimspeed
They have to be lowerd ones. I own two minis and tryed to fit normal spax but they dont close up enough.
Std type mini front dampers dont fit ether.
Re: Front Dampers
Posted: Thu Dec 08, 2011 9:13 am
by ulyssescale
panamesc wrote:i have those lowered spax on my lince , close to the softest set-up , it works like new dampers !
i've done some miles without any problems ....
Could you provide specific model type/number? I would like to order a pair of these for my Serveta Jet 200. I tried to search for "Lowered Spax" and all Google gives me is garbage. Spax site gives me too many listings.
Thanks from California, USA.
Re: Front Dampers
Posted: Thu Dec 08, 2011 7:38 pm
by Doom Patrol
Found these. Any help?
http://www.minispares.com/Product.aspx? ... u=C-STR305
On second thoughts probably not. But there are a lot of places doing Mini spares you could be looking at.
Re: Front Dampers
Posted: Fri Dec 09, 2011 12:18 am
by soullad
ulyssescale wrote:panamesc wrote:i have those lowered spax on my lince , close to the softest set-up , it works like new dampers !
these look like what you want
http://www.minispares.com/Product.aspx? ... 516&title=
check the closed and open lengths to see they'll fit, and remember to try and dial out as much compression as possible, certainly less than the inherent built in compression of your fork springs otherwise you'll run the risk of snapping your damper mounting lugs ! A typical standard lammy damper has almost no compression at all, and the rebound damping is an attempt to try and keep the tyre in contact with the road for as long as possible and prevent the front end from bouncing down the road.
