Page 2 of 2
Re: Won't start, occational backfire opinions please
Posted: Sat Sep 10, 2011 8:54 pm
by storkfoot
coaster wrote: ... just trying to avoid unnecessary faffing ;)
get a TS1, mate ;) You know you want to :P
PS, my money's on your snazzy stator :!:
Posted: Sat Sep 10, 2011 10:01 pm
by soulsurfer
lambytone wrote:Why prolong the inevitble, if it was me I'd get the barrel off and check for a blown head gasket
Posted: Sat Sep 10, 2011 11:44 pm
by coaster
Yes Mike I'm keeping my fingers crossed that is the problem too ;)
And Paul, I know where you're coming from mate but I hate admitting defete 8-) , got that clutch sorted yet? ;)
Posted: Sun Sep 11, 2011 8:24 am
by tobytyke
Excat same problem as i had...take the exhaust off and look up the exhuast port...i reckon youlle see the bottom ring as shed its peg...and gone walkies....(read my post)...i too was using a stage 4 indian head...i had the the head rebored and fettled at Mb,s..its perfect now.
Posted: Sun Sep 11, 2011 2:05 pm
by storkfoot
coaster wrote: ..... got that clutch sorted yet? ;)
turned out the the clutch was not slipping at all. It was a worn out drive spring and ramp on the front sprocket that made it seem like clutch slip. Mr. Winstone and Mr. Tid diagnosed the problem :bigsm:
Posted: Sun Sep 11, 2011 7:48 pm
by coaster
Update, managed to get a couple of hours on the scoot today, whipped the barrel off and was greated by this, you were right :cry: :
No sign of damage on the underside
Cleaned up ok and rings freed off easily enough
I reckon the piston at least started to go about 3 weeks ago when it suddenly lost power whilst I was giving it some stick. I noticed that the exhaust flange has been leaking so it might have been a bit weak. The piston is an MB Racetour and the crown seems very thick, there is no discolouration underneath the cratered area so I might put it back together and see how it goes before risking another piston in it.
Posted: Sun Sep 11, 2011 8:01 pm
by sean brady scooters
no discolouration you say ?
its all black and charred. :lol:
Posted: Sun Sep 11, 2011 8:05 pm
by Andy Pickering
A sad sad sight pal..id say first cause of action would be to investigate and seek the reason why its got so hot and started to eat the piston..
Posted: Sun Sep 11, 2011 8:16 pm
by Muppet
piston rings might be free but it's goin to get hot when it starts blowing past the damaged top ring groove,
:smug:
muppet
Posted: Sun Sep 11, 2011 9:47 pm
by coaster
Muppet wrote:piston rings might be free but it's goin to get hot when it starts blowing past the damaged top ring groove,
That is a good point.
Sean, what I meant was that the colouration is uniform, no localised signs.
