Page 2 of 2
Re: Mag flange question
Posted: Mon Sep 05, 2011 4:04 pm
by Supereibar
Well.. in all honesty I dont follow anyone, but it is in all the manuals that I read, that in order to make a racey engine, you need to make the compression higher. But then again what do I know?
J.
Posted: Mon Sep 05, 2011 9:49 pm
by wack 63
I think you will find certain racers already run this set up with an extra seal where the cup spacer sits but don't say I told you
Plus high primary compression is so yesterday ,let the exhaust do the work
Posted: Mon Sep 05, 2011 10:49 pm
by coaster
wack 63 wrote:I think you will find certain racers already run this set up with an extra seal where the cup spacer sits but don't say I told you
Hmm...this is sounding interesting
Posted: Wed Sep 07, 2011 11:43 am
by rakki
Muppet wrote:Is that how a vespa bearing is lubed; petrol oil mix,
On Vespas the carb sits above the crankshaft and that helps to lubricate the flywheel side bearing (crank side bearing is lubricated with gearbox oil).
Posted: Wed Sep 07, 2011 12:07 pm
by coaster
rakki wrote:Muppet wrote:Is that how a vespa bearing is lubed; petrol oil mix,
The mag flange I have has a channel running down from the transfer directly into the bearing.
Posted: Wed Sep 07, 2011 1:34 pm
by byron
coaster wrote:The mag flange I have has a channel running down from the transfer directly into the bearing.
like this :
Posted: Wed Sep 07, 2011 4:05 pm
by coaster
Yes Jarv, exactly like that.
cheers
colin
