Page 2 of 2
Re: Won't Run - Can't think of a more catchy title
Posted: Sat Aug 13, 2011 1:19 am
by GP240
Try/borrow a different carb.
Posted: Sat Aug 13, 2011 12:07 pm
by Bilko
I went out to take the cover off and I'd left the petrol on because there's a puddle.
Posted: Sat Aug 13, 2011 12:32 pm
by coaster
Bilko wrote:I went out to take the cover off and I'd left the petrol on because there's a puddle.
Float needle not sealing?
Posted: Sat Aug 13, 2011 1:41 pm
by Bilko
Thanks Colin. I took the plug out, as expected, wet. Took the carb apart. Float needle seems to be moving ok. I took it out and fired some compressed air through everything.
It's running now and I'll have to keep an eye on it.
I don't know what else to do. It'll be inpossible to try another carb.
RB250 with a LC Head
34mm VHSB Dellorto
Franspeed Tourer
It's developed a bogginess up to half throttle.
Posted: Sat Aug 13, 2011 2:26 pm
by Muppet
REEDS!!!!!!!!!
Posted: Sat Aug 13, 2011 2:43 pm
by Andy Pickering
Bilko wrote:Thanks Colin. I took the plug out, as expected, wet. Took the carb apart. Float needle seems to be moving ok. I took it out and fired some compressed air through everything.
34mm VHSB Dellorto
Franspeed Tourer
Do you think it was just badly flooded Bilko..
Posted: Sat Aug 13, 2011 5:47 pm
by Bilko
Yes indeed, flooded.
I had a leaky seal on the bottom of the carb. Sorted that now.
I was thinking of the float too because of the leak and poor running.
I need to try and sort the running out now.
Thanks Lads.
Posted: Sat Aug 13, 2011 7:37 pm
by Bilko
Possible second issue.
I was trying out with clip positions and then it wouldn't start. This time I popped the plug out. No spark. The last thing I thought of was the plug as I had a new one die on me midweek. But, I put on another old one in and it worked.
I'll keep an eye on it.
