Page 2 of 3
Re: bottom chain guide
Posted: Thu Jul 21, 2011 12:36 pm
by Bilko
Out.
I've never used them.
Posted: Thu Jul 21, 2011 2:27 pm
by byron
obviously I've never seen it, but I'd imagine there would be fair amount of lash going on, when shutting the throttle, before the gearbox slows down to the same speed as the crank...
I do generally shorten them a bit at each end.
if you do fit one of the nylon bottom guides, make sure it is carved about enough to allow the chain to run straight...
Posted: Thu Jul 21, 2011 5:38 pm
by bazman
Out , never had a problem.
Posted: Thu Jul 21, 2011 10:59 pm
by goldeneye
out. after witnessing one snap, and jam the chain solid, on woodys 225 rapido on the way to lincoln for the euro, and it locking the engine solid with no warning, i"m never fitting one again. the uprated top chain guide is all i fit.
Posted: Thu Jul 21, 2011 11:03 pm
by RICSPEED
probably a better bet would be to fit one of the Teflon ones if only to stop the chain damaging the case
Posted: Fri Jul 22, 2011 12:09 am
by coaster
goldeneye wrote:out. after witnessing one snap, and jam the chain solid, on woodys 225 rapido on the way to lincoln for the euro, and it locking the engine solid with no warning, i"m never fitting one again. the uprated top chain guide is all i fit.
I don't bother with the bottom one either for the same reason, never noticed any marks on the bottom of the case.....plenty on the top though
Posted: Fri Jul 22, 2011 12:18 am
by Muttley McLadd
Doesn't fitting a 'pull down' top chain guide negate the need for a bottom one?
Posted: Fri Jul 22, 2011 9:24 am
by red ghost
In and funnily enough it's something I bought from mr. tino that works
Posted: Sun Jul 24, 2011 8:41 am
by stew
Posted: Sun Jul 24, 2011 9:47 am
by red ghost
There are only some who are smarter than the Innocenti engineers..
So, use both, it's better value for money(if bought as a pair)... and as intended by the said engineers.
And just to reinforce the point, would you remove a chain guide from your car?
