Page 2 of 3
Re: Avanti TT3
Posted: Tue Jul 05, 2011 6:09 pm
by coaster
teamsequipe wrote:
coaster wrote:I notice the fins near the inlet port are cut back, in readiness for a reed manifold??
I think you'll find it's to clear the frame tube, yes, the barrel is THAT big !!
Thanks for the clarification Darrel, looking at it again I can see that the cowl is shaped to follow the 'relieved' fins.
Re: Avanti TT3
Posted: Thu Sep 29, 2011 7:12 pm
by OAP
First batch are being delivered by the 7th October, so who is going to get theirs on the road first?
If you would like to see the TT3 kit I will be at Wicksteed Parts Fair on the 16th October
Re: Avanti TT3
Posted: Mon Oct 17, 2011 4:34 pm
by badal1965
Finally fired mine up today and i've done 25 miles.Still playing with the jetting but it's feeling good so far.
Re: Avanti TT3
Posted: Tue Nov 01, 2011 8:19 pm
by cezeta
badal1965 wrote:Finally fired mine up today and i've done 25 miles.Still playing with the jetting but it's feeling good so far.
any more feedback?
Re: Avanti TT3
Posted: Mon Nov 07, 2011 4:45 pm
by badal1965
Yeah sorry,
I've done over 400 miles now and still jetting.Bottom end is sorted now with thanks to Ron.Changed to a richer X13 needle from a X7 to try and sort the midrange out. :D
Re: Avanti TT3
Posted: Mon Nov 07, 2011 6:08 pm
by cezeta
hows it feel?
Re: Avanti TT3
Posted: Wed Nov 09, 2011 9:41 pm
by Lambretta Sash
A surreal Smooth experience 8-)
Just setting mine up at moment but first impressions are good and it pulls TV200 gearing which is what i've wanted having 3 gear boxes kicking about!!
Kit fits well and its handy that all components are there including the different base gaskets which makes life easy, standard 30mm manifold only needs minimal matching too
Once ive stopped playing with crank/carb/pipe/ign etc i'll dyno it
Re: Avanti TT3
Posted: Thu Nov 10, 2011 12:38 pm
by badal1965
What ignition system were/are you running?
Re: Avanti TT3
Posted: Thu Nov 10, 2011 7:07 pm
by Lambretta Sash
Varitronic set at 21/22 deg before retard hits although i will probably change this to Electrex once funds permit.
What crank are you using?
Re: Avanti TT3
Posted: Thu Nov 10, 2011 7:47 pm
by badal1965
Mazuchelli.I've just taken my variotronic off and i've gone back to a normal one with a lightened/welded Indian f/wheel.
