Page 2 of 2
Re: T5
Posted: Thu Jun 30, 2011 11:41 pm
by gee
Right, i'll check the clutch sprocket after i get back from camber, thanks fellas
Then if it's found to be 22 i'll get it changed and try that.
Re: T5
Posted: Fri Jul 01, 2011 12:57 am
by buttontobutton
sean brady scooters wrote:I bet you find its been fitted with a 22 tooth clutch sprocket ,which would work fine if it was ported tuned and reedvalved...
21 tooth should be ok though with that pipe .
If you like constantly working back and forth between 3rd and 4th gear , yes, it will be fine with a 21 tooth and a PM. Being less than 10 stone and riding only with the wind behind you will also help.
Re: T5
Posted: Fri Jul 01, 2011 12:30 pm
by gimp1971
get rid of the pm got a scorpian om my reedvalved 172 and with the pm was pulling 15.5 hp put scorpian on and just over 18 thats with a 20 tooth clutch as had a 21 on with the pm and it was rather poo might retry it now as think 4th would pull it well now
Re: T5
Posted: Sun Jul 03, 2011 8:44 pm
by markauk
my T5 Polini 152, machined head, 21 clutch, 26mm carb, augusto 7000 had a sterling pipe and did the same, fading out at top but on long runs it'd eventually wake up and hit 70 usually just before a roundabout or a junction!. Today I put a scorpion on and will do a long journey later in the week so I'll test it then, but around town today it really turns it into a loud revvy little bitch!
Re: T5
Posted: Mon Jul 04, 2011 11:15 pm
by markauk
DOH!, I meant Simonini not Scorpion
Re: T5
Posted: Wed Nov 16, 2011 5:55 pm
by gee
It's been a while and i'd almost forgotten but, i changed the rings and ran it for a while before giving it some proper stick, managed to hit 68 on the gps which i suppose isn't too bad, but that was revving the nuts off it.
Re: T5
Posted: Thu Nov 17, 2011 10:58 am
by vespapaulo
My T5 ran a malossi 172 standard up jetted carb 21 tooth cosa clutch and a PM pipe, it went like the clappers.
Re: T5
Posted: Thu Nov 17, 2011 11:01 am
by vespapaulo
With the setup you have you should be getting well over 70MPH.
something is wrong with the set up. Clutch would be my first stop.
