Re: off set engine frame/engine cones
Posted: Thu Jun 16, 2011 10:42 pm
The problem with the offset cones is that they both need to be in the same plain, eg slots lining up. It doesnt matter with the normal ones as they are the same width and so roation doesnt come into it. I tried silicone but they still kep moving. I used a 2 part glue which worked but this took 2 attempts. Before i tried the 2nd time i got the dremmel out and cleaned up the inside of the cones with a sanding bit then flatted down the bar to make sure it slid in and out as best as poss.
In hindsight the silicone would have prob been okay if id have prepped properly. Some bars seem to slide through okay others like mine always need some persuasion...
