Page 2 of 15
Re: Winter Model, Summer Restoration...
Posted: Wed Jun 15, 2011 5:07 pm
by soulsurfer
Thanks Bofs, pm sent ;-)
Okay some more knackered parts...
Speedo held together by grease and Evo-Stik
Beyond renovation??
Holes in the headset top and bits broken off the edges...
Not sure if this is the correct headlight unit, but one of the lugs is broken...
Is this supposed to be welded inside the RH panel?
And this is where we're at now, a couple of bits removed off the back end, looks like one of them trailers now...
The grinder and cutter and Dremel are getting some use. :evil:
Off to see my ally polisher and welder man tomorrow, he can also dip and strip the ally parts, so we'll see what that will reveal!!
Posted: Wed Jun 15, 2011 5:21 pm
by Lambrettatastic
what petrol tap lever do you need,is it series 2 or 3 style on these?
Posted: Wed Jun 15, 2011 5:32 pm
by soulsurfer
It's Series 2 on these. It does get confusing though, it even has a Series 3 airscoop :-?
Posted: Wed Jun 15, 2011 5:38 pm
by RICSPEED
soulsurfer wrote: Is this supposed to be welded inside the RH panel?
yes
Posted: Wed Jun 15, 2011 5:44 pm
by soulsurfer
Cheers Ric, it's on;y on the RH panel, why's that?
Both panels also have that small plate welded to them, some kind of reinforcement? Can't see that area being a weak point though :-?
Posted: Wed Jun 15, 2011 5:54 pm
by Ian Hepworth
soulsurfer wrote:Cheers Ric, it's on;y on the RH panel, why's that?
It's where the panel sometimes touches the footboard arm, it's prone to cracking there.
Posted: Wed Jun 15, 2011 6:02 pm
by soulsurfer
I'll leave them then ;-)
Posted: Wed Jun 15, 2011 6:05 pm
by RICSPEED
only plausible reason i can come up with is it may have been felt that this area may take a few knocks being in close proximity to the kick iron ....and judging by my right hander they were spot on :?
Posted: Wed Jun 15, 2011 6:06 pm
by WINTERMODEL150
Got some pics of my winter model i restored a couple of years ago.
pm me with any questions.
Dean.
sold it to a friend with regrets now :(
Posted: Wed Jun 15, 2011 6:13 pm
by Doom Patrol
Keep the glass from the headlight unit whatever you do. You're unlikely to find another and it can be glued onto a pattern reflector.
