Snapped stainless sterling
Donnie
looks very thin that!
Donnie.
dapper
I've had two ScootRS downpipes go on me in exactloy the same place, hence won't be using SS again. Here's a photo showing how thin the walls of the downtube are at that point. Wiped the piston both times.
Putting an Injun big bore on instead as this reboring and new piston lark is expensive
djh66
Main scooter: 150 special
Dapper, that's exactly the same as mine (only better photo's :)
Bring Me Sunshine COYH
lamblast
ive got one on me 200 vega but converted it to solid mount as i had a feeling being rubber mounted and stainless it would fall to bits, recently had it dynoed to check the air fuel ratio and found out the exhaust kills it at just over 6000 rpm so its going on ebay
djh66
lamblast wrote:ive got one on me 200 vega but converted it to solid mount as i had a feeling being rubber mounted and stainless it would fall to bits, recently had it dynoed to check the air fuel ratio and found out the exhaust kills it at just over 6000 rpm so its going on ebay
It was solid mounted!
djh66
Not only around the manifold,but as you can see, two of the welds on the main exhaust cracked aswell.
By thatnuttysound at 2011-06-14
lamblast
sterlings are not solid mount they use rubber mounts on the side casing and springs on the mainbox to manifold join
djh66
lamblast wrote:sterlings are not solid mount they use rubber mounts on the side casing and springs on the mainbox to manifold join
This one did have the springs, but no rubber mounts on the side casing.
