What 2 Stroke Oil are People Using on their RB Kits?
jonashford
Bilko wrote:
jonashford wrote:....... just leaking gearbox oil through a small crack in the casing...
No overheating problems any more yippeeee!
Where's the leak from?
My casing cracked too, where one of the bottom cylinder studs was.
On the way to elvington the rear mount for the franspeed, the bottom bolt snapped in the casing, also chipping away a small piece of alloy from the inside of the casing oil was leaking out so i decided to head back home rather than carrying on, I wasnt happy.
Fixed it now tho so all is good in the hood
Bilko
Main scooter: LI150
Ah that's ok. Glad it's nowhere else and sorted.
Bilko's Oily Blog
RBG
Rockoil or Motul 800
ABC
Main scooter: mk1 t5
rb22// nk race ..34mm delorto ..af rb crank thrashed for 4 years on silkolene scoot sport 2 at 4% never missed a beat. run it in my t5 mallossi at 3%
KCB
The RB kit cc's -225
Miles rode -3k approx
Failures -no heat seizes, clutches, piston threw ring peg etc
% 3 or 4 - 2%
Any other observations -still smokes when first starting
TYPE OF OIL - Castrol TTS or whatever it is called now
Gabo
RB 22
crank 12000
Head Mitolambretta
Manifold Seven
Mikuni tmx 35 (315 main,60 needle on 2 from top clip, 17.5 pilot jet)
Exhaust Jolly Moto
Varitronic and Gear DRT (1; 3; 4)
Complete Cluth Stratos , 46/17
4500km
No problem (only 1 rubber manifold dead)
Oil: Motul 800 or ELF htx 976 = 2%
soosh
Im waiting for someone to say "Groundsman" by Rock oil.
Spaceman
Main scooter: Lambretta GP125 (RB20)
The RB kit cc's -200
Miles rode -1.2K
Failures -none
% 3 or 4 - 3 and a bit
Any other observations -smokes a bit when pootling around town.
TYPE OF OIL - AGIP racing fully synthetic. Fortified with castor oil so it smells fantastic! 8-)
