Re: TS1 Ron Moss Ts1
Posted: Mon Jun 06, 2011 4:45 pm
Hi guys thanks for all the help
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
What set up did JB tune the barrel for? Did he tune it to run an expansion or a clubman as this will make a big difference to the way it runs.shedboy wrote:Hi mate its JB Road tuned ts1 with 35mm mukui off hand could tell you what the jetting is but i have look and let you tomorrow but is spot on for plug color i just have problems on hill and into the wind ill try changing the gearing as advised
shedboy
Hope your not running std piston height cos it'll be sticking out of the top of the bore.mickdale wrote:yes m8shedboy wrote:Hi guys
Is any one ruining a Ts1 with a Ron Moss clubman what gear box are you using.I have li 150 17x46 giving me 4.6 but it is hard work in 4th all right on the strait but struggles into wind ore up hill i am not a small lad 17stone any help would be great
thanks shedboy
got 60mm crank and 1.5mm machined from the base
runs i ndian gp with 20/47 (4.7) no worries
yes std mitaka pistonSpecial X wrote:Hope your not running std piston height cos it'll be sticking out of the top of the bore.mickdale wrote:yes m8shedboy wrote:Hi guys
thanks shedboy
