Page 2 of 2
Re: How much dmage
Posted: Wed May 18, 2011 11:44 pm
by sydduckett
Bilko wrote:Happy days! No put your wallet away!
Cheers bilko. by the by i saw you on the LCGB site re the MB rubber exhaust gasket thing. They do fit a franspeed well the francespped race anyway. Have one on mine. Just need to dip in a cup of hot water first and then toll the metal split rings into the grooves once you have it in position. Mine is a bit tatty now but that down to the end can being removed a few times...
sef
Re: How much dmage
Posted: Thu May 19, 2011 12:08 am
by coaster
sydduckett wrote:Panic over, just been out to the garage and checked the plug. same as you plug had jumped straight out. Looks abit knackered so will swap for a new one tomorrow and see how it goes.
Make sure you do the Lottery this week, sounds like you're on a lucky streak ;)
Re: How much dmage
Posted: Thu May 19, 2011 1:03 am
by corrado
I'd be checking the plug threads in the head unless it was just the lead falling off.
Re: How much dmage
Posted: Thu May 19, 2011 9:13 am
by Bilko
sef
Here's why it won't work Sef. The bracket for the support goes right up to the edge of the joint. I use silicone, but it never lasts.
Re: How much dmage
Posted: Thu May 19, 2011 10:15 am
by nelson pk
Hi guys
Just reading this thread and saw the issues with the exhaust end can joint.
I can recommend the high temp exhaust gasket sealant that camb lamb sell for all exhaust slip joints. I found it works really well.
Its expensive (close to £20 a tube) but lasts for ages. I've had my tube for two years now and have popped my pipe off several times and my mates and refitted (Ooooooohhh errr! Lol!) and it still heasn't run out and i've never had a leaky exhaust joint.
Hope this helps!
Pete.
Re: How much dmage
Posted: Thu May 19, 2011 5:54 pm
by GP240
Slip joint (JL3)
I took the end can off then cut some slits into the outer part of the joint, slid the can back on and closed it up with a jubilee clip, 4yrs an still tight.
Re: How much dmage
Posted: Thu May 19, 2011 9:46 pm
by TS1-200
sydduckett wrote:
#1GP200 wrote:Exactly the same thing happened to me recently, the same symptoms, even pushed it home in the rain too.
Thought it was a holed piston but after investigation it turned out that the spark plug worked loose and
popped out. Hopefully thats all thats happened to you.
Could have done it at side of road and saved myself a hernia... :D
Lucky man, last time I had exactly those symptons it was a gudgeon pin circlip popping out in my TS1, never realised how much damage a little bit of wire could cause :o ,
Re: How much dmage
Posted: Fri May 20, 2011 9:42 pm
by sydduckett
sef
I see what you mean, the franspeed tourer is differnet to the race or maybe an updated model? iv already had to re rivet the bottom band on the end can 2 times... :evil: Bloody things.... :D
