Inlet timing too much?
nelson pk wrote:Its a rubber mounted carb. I'll try going back to the 250 needle valve and see if that makes a difference.
Try blowing carb cleaner through the main jet orifices while you are at it to make sure they aren't blocked.
nelson pk
Thamks for all the replies. it really is much appreciated. i will try all suggestions and post back any findings. Any other suggestions are more than welcome.
Pete
