Re: Tubeless valves.
Posted: Mon May 02, 2011 9:31 pm
Probably don't need to chop this much out, but I couldn't be arsed with a dremmel.
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
Alright Dan, not exactly sure what you mean, but the sleeved part of nut that holds the valve in, shouldn't go into the hole at all, otherwise it wouldn't tighten up. It would stop the valve itself fom seating properly. So, have you got the right size valve? The nut should pull the valve itself tight to the rim.dansuper wrote:Just to clarify - I'm doing this conversion, too - does the 'sleeved' section of the valve nut sit flush in the hole in the rim? Trying to work out if I need to file the hole a bit bigger as the nut won't currently fit in the hole.
Please stop me if I'm about to fook it up!
Thanks,
Dan
Thanks for that! All clear now.Ihateyoubutler wrote:Alright Dan, not exactly sure what you mean, but the sleeved part of nut that holds the valve in, shouldn't go into the hole at all, otherwise it wouldn't tighten up. It would stop the valve itself fom seating properly. So, have you got the right size valve? The nut should pull the valve itself tight to the rim.dansuper wrote:Just to clarify - I'm doing this conversion, too - does the 'sleeved' section of the valve nut sit flush in the hole in the rim? Trying to work out if I need to file the hole a bit bigger as the nut won't currently fit in the hole.
Thanks,
Dan
Maybe some confusion as I'm standing upside down as I write this because of where you live :biggrin:
Ring them blokes from the fosters advert, they'll put you right :biggrin:
[/img]
