Page 2 of 2
Re: Home Made Exhausts?
Posted: Mon Apr 11, 2011 2:38 pm
by Wayne Miller
Posted: Tue Apr 12, 2011 6:53 pm
by fairspares
if you get fed up and want to make something a bit quicker a good pipe to cut up for small frame vespas is the yamaha rd pipe , you can pick them up pretty cheap on ebay , i made one that went down and forward under the frame and it worked a treat.
Posted: Tue Apr 12, 2011 7:32 pm
by Wayne Miller
fairspares wrote:if you get fed up and want to make something a bit quicker a good pipe to cut up for small frame vespas is the yamaha rd pipe , you can pick them up pretty cheap on ebay , i made one that went down and forward under the frame and it worked a treat.
I have an aprillia pipe in the shed that I could cut up but it wont be what I want. I want max power at 11500rpm plus I like the idea of designing my own pipe
It will work . . . . . I'll make it work
Heres the pattern I cut out yesterday for the straight pipe . . .
I was going to cut the pattern in steel tonight. I got some 1mm steel off a mate but when I got it home I realised it was 1.5mm instead of the 1mm I asked for
Ive been told to get rid and get some 1mm as its a lot easier to work with so Im now on the hunt for some 1mm
Posted: Wed Apr 13, 2011 10:05 pm
by Wayne Miller
Pattern, now cut in 1mm steel below, stinger still need to be cut to size
This a straight pipe that will come straight out of the back of the scoot. That way I can alter it easily
Posted: Sat Mar 10, 2012 8:26 pm
by grimspeed
So what hapend next ?
