Page 2 of 2
Re: PSI Tyre
Posted: Fri Mar 13, 2009 9:51 pm
by Andy Pickering
cryogenic wrote:Hi Den what size tyre is it your running on i run the weatherman 190 / 10 on the rear and the paceman on the front both on standard rims wide rims wont fit with this size of tyre on the rear due to engine casing clearence i ran at 35psi to sweden and back. A little wear was noticed but i put this down to over 2300 miles being covered and i was towing a trailer.
kind regards
Running racemans 100/90..front 28 standard rim-Rear 32 wide rim all fine so far no rubbing as yet...Living on salad though
Re: PSI Tyre
Posted: Fri Mar 13, 2009 10:02 pm
by J1MS
Ive built up my 100/90 Weatherman ( 4 inch Rims )about 3 months ago with the intention of putting it on the rear of my GP.... Looks like it could be a tight fit
If I fit a second washer, or have a deeper one made for behind the hub cone to space the wheel and tyre further away from the engine case.......This shouldnt cause me any problems.....WILL IT...???
Re: PSI Tyre
Posted: Mon Mar 16, 2009 2:09 pm
by mickeyb
i run 100/90 on the rear with a spacer on each of the studs with a wide rim...no rubbing of the tyre on the casing however ive had a flat and i find i have to fit the rear tyre deflated and inflate it when fiited.
Re: PSI Tyre
Posted: Mon Mar 16, 2009 8:20 pm
by byron
mickeyb wrote:... a spacer on each of the studs ....
do you mean between the rim & the hub ?
then surely the rim is not seated on the hub safely ??
I can now remove my 100/90 on a wide rim without deflating after doing this mod from the MB site :
oops! that pic is huge!
Re: PSI Tyre
Posted: Mon Mar 16, 2009 9:01 pm
by mickeyb
I put a spacer on each stub where the rim/tyre sits on,its fully flush....works a treat...good idea cuutin the fins off the hub however mines a chrome one.
