Page 2 of 4
Re: MB digital speedo
Posted: Wed Apr 13, 2011 8:41 am
by bizzly
chris2470 wrote:I also had the random speedo readings on my display, bouncing all over the place when the rpm's went up, but I have now found a way to solve it.
I got some tinned copper earth braiding from RS Components, opened it up and simply threaded the entire length of the rev counter pick up wire down the inside of this. I left the braid a bit longer at one end so that I could connect it to the frame, both ends would probably be better if needed. Then wound the red pick up wire round the HT lead only a couple of time and fired her up.
So far no problems at all, totally smooth and still running the speedo in a standard AC regulated supply.
What, the whole length..ie: from the speedo to the ht lead or just the thin bit of wire that pops out from the outer sleeve?
Posted: Wed Apr 13, 2011 11:32 am
by chris2470
I screened the whole lenght , from the Speedo to the HT only leaving exposed the red copper wire that wraps around it.
This may seem a little bit belt and braces but it has so far worked for me.
Posted: Wed Apr 13, 2011 9:36 pm
by bizzly
Cheers for that Chris. If I do have a problem (haven't tried it yet since realigning it) I will give that a go. I don't fancy mucking about trying to fit the Koso 12volt DC thingy on that I got.
Bizz
Posted: Thu Apr 14, 2011 12:06 am
by Lazarus
it was my speedo that Monty set up and I will be phoning MB this week to ask for help as its still not right including badly misting up when it was sunny on Gingers egg run.
But I like your idea chris
Posted: Thu Apr 14, 2011 7:59 pm
by bizzly
Oh yea......and it misted up like yours Laz
Posted: Thu Apr 14, 2011 8:56 pm
by Craig H
Iam sure I saw some gorillas in mine, very misty but have had it for a couple of months now so when the SIP ones come out it will be on evil bay.
Posted: Thu Apr 14, 2011 9:08 pm
by Craig H
Just had a thought would it get rid of the mist if there was a small hole in the base of the speedo or make it worse?
Posted: Fri Apr 15, 2011 12:49 am
by bizzly
Craig H wrote:Iam sure I saw some gorillas in mine, very misty but have had it for a couple of months now so when the SIP ones come out it will be on evil bay.
Sip ones are out....£135...and they run off the normal speedo cable
Posted: Fri Apr 15, 2011 12:51 am
by bizzly
Craig H wrote:Just had a thought would it get rid of the mist if there was a small hole in the base of the speedo or make it worse?
I'm going to ring MB to ask him if it would be ok to drill a 1mm hole, or if that would invalidate the warranty.
Posted: Fri Apr 15, 2011 7:57 am
by Bilko
bizzly wrote:Craig H wrote:Just had a thought would it get rid of the mist if there was a small hole in the base of the speedo or make it worse?
I'd say theres a good chance of invalidating the warranty.
You could catch something inside the housing with the drill.
