Re: wont start
Posted: Mon Mar 28, 2011 7:27 pm
have you timed it the right side of top dead center ,as you look at stator engine tuirns clockwise ,
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
Yes , marked TDC then marked 19 degrees from the left of TDC which is anti-clockwise..twin peeks wrote:have you timed it the right side of top dead center ,as you look at stator engine tuirns clockwise ,
no new plugs are not pre set................just try it at about 0.5 <> 0.25Piatti wrote:Yes , marked TDC then marked 19 degrees from the left of TDC which is anti-clockwise..twin peeks wrote:have you timed it the right side of top dead center ,as you look at stator engine tuirns clockwise ,
'try closing the gap on the plug then try it'
What gap does it have to be, its a brand new plug so shouldnt it be pre set,
I have a feeler gauge so can check if someone knows the correct gap![]()
regards
Piatti
RICSPEED wrote:no new plugs are not pre set................just try it at about 0.5 <> 0.25Piatti wrote:Yes , marked TDC then marked 19 degrees from the left of TDC which is anti-clockwise..twin peeks wrote:have you timed it the right side of top dead center ,as you look at stator engine tuirns clockwise ,
regards
Piatti
dapper wrote: If you are going on the timing marks on the flywheel, they could be out.
I think he's referring to the pick up lines on the stator and flywheel that help get the stator in an approximate place to allow the engine to run (pre strobing), not the firing point/flywheel arrow marks.RICSPEED wrote:dapper wrote: If you are going on the timing marks on the flywheel, they could be out.
hell yeah ....if you get an old plug and remove the center ceramic bit and put a bolt through it ...put in head and mark the point on your mag housing by Turing flywheel buy hand both ways until it cant go any further ...mark both points and half way between these is tdc
