Re: repair the ts1 or go for a rapido 250?
Posted: Wed Mar 11, 2009 10:10 am
Foxy in Goole ran, or rather thrashed a Rapido 250 and loved it. Can't remember what he's running now, but he loved it.
Keep the TS1.
Keep the TS1.
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
I was lead to believe that AF rayspeed had fitted these here single ring Bultaco pistons to an RB 250 to see how it might perform in the RB Group 6 sponsored race scooter... They look a very nice piston (Teflon coated) and from what I was told, not that expensive Considering...Supereibar wrote:Neither... go for a Bultaco 250 conversion![]()
............ repair the TS1.
Please tell us you're gonna get it dyno'd and post a graph - otherwise you'll suffer the wrath of Adspeedcezeta wrote: the new spec is
71mm race tour piston
60mm alpha crank
240cc
unleaded low comp head recessed so no gaskets
lengthened barrel adding an extra cooling fin
i kept the 90s af ignition but may fit a heavier flywheel if constant road speed is an issue
b race stealth pipe
mbd inlet manifold modified and matched to take v force reeds
reedspeed 6 plate clutch
tmx35 with a breath sweet filter running under the diablo tank
its a race tour spec tune +
the plus is an experiment with the exhaust port, after pestering mark b and generally winging that the lambretta was not a 4 stroke ohc single or v twin he came up with a new shape exhaust port to produce torque which involved welding and filing and .....all that stuff that they do
No, the piston I saw would have revved well past 7000 rpm with ease. Its a single ring performance piston, What model its off Im not sure, but one ring thats only about 1mm thick would be capable of a couple of thousand more revs, I would have thought.Juan wrote:Just my thoughts here and I don't know Bultaco's range but to my knowledge they only make Trials bikes.
Now, presuming they don't do Enduro's or ' Crosser's that means it's designed for a low revving engine. Obviously there'll be a safety margine built in but why would you use a piston designed for say 7,000 RPM if the kit could run well above that from what I understand?
Stokie wrote:Please tell us you're gonna get it dyno'd and post a graph - otherwise you'll suffer the wrath of Adspeedcezeta wrote: the new spec is
60mm alpha crank
240cc
b race stealth pipe
the plus is an experiment with the exhaust port, after pestering mark b and generally winging that the lambretta was not a 4 stroke ohc single or v twin he came up with a new shape exhaust port to produce torque which involved welding and filing and .....all that stuff that they do![]()
It'll be interesting to see a comparison to the large cc Foxhat motors whenever we get to see something about one of them .......
