help with winter model turning mudguard please
Supereibar
Quite proud of that myself :lol: :lol: :lol:
smoore-gt225
Main scooter: lambretta GT200
RICSPEED wrote:
smoore-gt225 wrote:
Supereibar wrote:Great job & nice scoot but that is not a Winter model.... :roll: ;)
J
hi yes i should of said replica, trying to find a headset but will have to do with a series 2 at the moment
cheers steve
tring to spanishise an italiain scoot .....oooohh what would they say ont' t'other side??? :lol: :lol:
hi im not worried about what people say just look at my tv200
i am in no way an anorak :lol:
cheers steve
not suggesting you are :lol:
its funny though is it not that people get there Keck's in a twist about Indian gp's with "i" badges and you making a Italian scoot look Spanish ....best not put an eibar badge on it ey :lol: :lol: :lol:
soullad
Supereibar wrote:As far as I know, there is no dust protection cup on ANY of the Series II's that have come out of Spain. Or at least there wasnt on any of the ones I've taken apart. The Spanish models have a spacer thin ring between the frame and lower bearing track. Did you find it like that or is it an Italian Series II frame you are trying to fit that on? I think that is the problem.
Do the following:
1- Remove the dust protection cup (and lower bearing track).
2- Refit bearing track
3- Fit fork race & greased cage
4- Fit the spacer ring
5- Gently sit the mudguard & clamp on the spacer ring
6- Acomodate the fork in place but dont tight it yet.
7- Time to locate the front mudguard
8- Find a set of bolts that will be discrete on the mudguard. Originals where phillips headed, now I find that the flat heads are far easier to fit.
9- Tighten the mudguard and do the upper steering cone.
You're ready to roll,
J.
Wise words from J.
When you come to fit the forks / mudguard for real don't forget to thread the speedo inner (the wrong way round / upside down) in place before you bolt the mudguard inner in place ... otherwise it can be a right pain in the ass. The front brake cable isn't so tricky as it simply fits into the external hole on the mudguard, from under the horncast. I've always thought that an hydraulic hose routed outside the panelwork straight from the handlebar down thru this hole, (ala Group 4 race scoot) would look very trick.
I'm also inclined to side with Bofs, in that the race mount itself looks odd, and yours has a step some 5-10 mm down from the lip ..why is that? Hs it still got an old inner ring on it, or did the recess fit the extra depth of the original dust cover?? Intriguing ..well to me anyways :lol: :lol:
Hope that helps
Ian
im i correct that the collar on the forks is the same size as the frame tube??
soullad
RICSPEED wrote:im i correct that the collar on the forks is the same size as the frame tube??
good question mate, I'll just go and chop up a frame and let you know 8-) Have you a recently butchered frame and need to make up a collar??? I'll measure the ID and ODs of the collar and get back to you.
ohhh first Eden now you.... :frog:
I'm sure you said so mate :D
