Page 2 of 3
Re: Scootering TS1 Exhaust Test
Posted: Thu Mar 03, 2011 10:22 am
by Speed Demon
Lam46 wrote:I will stick with my PM25 cause it does what it says on the tin..and when it falls to bits it will be replaced with an ads.. ;)
The ads seem to fare very well in the test and yes I agree that in my experience the Nk does tend to self destruct a bit dunn it bro.. :D
The irony here is that the ADS and the NK pipes are now made by the same fella with the same bracketry, though to be fair it's light years ahead of the old NK stuff.
Posted: Thu Mar 03, 2011 11:18 am
by Mag
Sticky, some of those pipes that really appeal look a little fat. Will there be a test to see if you can still lean with them on? A road test would be nice to see how they perform on the road.
Posted: Thu Mar 03, 2011 11:36 am
by sydduckett
I for one enjoyed the pipe test but i feel it only tells part of the story and thats not really down to the mag as they only have so much space. We saw road pipes, race pipes and tourers being tested which are all designed to give the power in different places. Also very little was given to how they perform at low revs around town/in traffic ect. I have 2 of the raod/race pipes that they mention and they are a bit of a pain in the a**e at low revs to put it mildly. .... :D
Posted: Thu Mar 03, 2011 11:57 am
by Speed Demon
Mag wrote:Sticky, some of those pipes that really appeal look a little fat. Will there be a test to see if you can still lean with them on? A road test would be nice to see how they perform on the road.
It took more than a day simply to fit and dyno them all - testing them all on the road is not feasible in terms of time, however the top 3 we could certainly try on the road. I've still got the NK Road to play with but all the others have either gone back or are up for grabs in the competition. We'll see.
Posted: Thu Mar 03, 2011 12:04 pm
by Speed Demon
sydduckett wrote:I for one enjoyed the pipe test but i feel it only tells part of the story and thats not really down to the mag as they only have so much space. We saw road pipes, race pipes and tourers being tested which are all designed to give the power in different places. Also very little was given to how they perform at low revs around town/in traffic ect. I have 2 of the raod/race pipes that they mention and they are a bit of a pain in the a**e at low revs to put it mildly. .... :D
You can tell how bad these will be round town by comparing the graphs at 5,000 rpm. A good all-rounder like the Devtour is making about 13hp which is nice and driveable, The JL4 is making only around 11hp (approx 20% less) and the ADS3 is making 17.5hp (approx 35% more) so there is a massive range of difference which is not necessarily reflected in the peak power outputs.
Posted: Thu Mar 03, 2011 8:50 pm
by twin peeks
ive got a taffy pipe on my ts1 ,with 34mm koso carb 5.2 gearing .this set up does all the things you want,like atwist and go low down ,.wind it up through the gears goes really well ,the nk pipe i had before all top end and kept coming loose
Posted: Thu Mar 03, 2011 9:48 pm
by camel
twin peeks wrote:ive got a taffy pipe on my ts1 ,with 34mm koso carb 5.2 gearing .this set up does all the things you want,like atwist and go low down ,.wind it up through the gears goes really well ,the nk pipe i had before all top end and kept coming loose
i think we,ve established its an all new nk pipe so talking about the old nk is pointless.
i think the carb was a little small for my liking on the test scoot but id like to hear from someone who has one on a road bike
very interesting after all the "plugging" on here for other pipes
Posted: Mon Mar 07, 2011 7:13 pm
by Speed Demon
There was a mistake in the layout in the mag and the graph for the High Rpm pipes was not included.
It is now up on line at http://www.scootering.com/news/lambrett ... rect-graph
Posted: Mon Mar 07, 2011 9:27 pm
by Adspeed
Sticky how come you have put the ADS5 (Fast Road) in mid rpm catergory and the Fran Race in the High rpm cat? ADS5 and the Fran Race came out all but the same even peaking within just 50 rpm of each other? Remeber we couldn't believe it when we did the test?
When you look most pipes (The new ones anyway) peak the same in mid and high graphs bar our race pipe that didn't really work and needs a good handful of port duration but it is called a Race for a reason! (designed to peak at 9k thats how mismatched to the barrel it is-reckon needs another 10-15 deg!)
Posted: Mon Mar 07, 2011 9:54 pm
by soosh
Will you be doing the same again on a non reed motor?
