Page 2 of 2
Re: Engine cuts out when taken out of neutral____ clutch??
Posted: Thu Feb 24, 2011 10:47 pm
by storkfoot
Thanks, lads. I'll look into all these points at the weekend
I didn't think the kickstart spring looked right either but according to Sticky's the kinked end goes in the shaft. I took that to mean the end that has a straight bit
Posted: Sat Feb 26, 2011 6:07 pm
by storkfoot
Other than it definitely not being the cable adjustment, or reach of the lever, I'm not sure what it was in the end, but I now have an operational clutch
I suspect either bending up the ears of the bottom cork plate, or possibly the kickstart spring being the wrong way round
Thanks for all your help
Posted: Sat Feb 26, 2011 7:52 pm
by Angry Bloke
All's well that end's well.
You on the road now Paul or does it need registering ?
Posted: Sun Feb 27, 2011 12:44 pm
by dapper
storkfoot wrote:Other than it definitely not being the cable adjustment, or reach of the lever, I'm not sure what it was in the end, but I now have an operational clutch
God I feel smug
Posted: Sun Feb 27, 2011 1:05 pm
by storkfoot
Angry Bloke wrote:You on the road now Paul or does it need registering ?
Peachy, Just need a disc brake caliper from CS, which I'll be ordering tomorrow, a hole in the panel, and a bit of a fettle with leaning the carb at the bottom end, and then I'll be booking in a pre-registration MOT :fb:
