Engine cuts out when taken out of neutral____ clutch??
storkfoot
Thanks, lads. I'll look into all these points at the weekend ;)
I didn't think the kickstart spring looked right either but according to Sticky's the kinked end goes in the shaft. I took that to mean the end that has a straight bit :?
storkfoot
Other than it definitely not being the cable adjustment, or reach of the lever, I'm not sure what it was in the end, but I now have an operational clutch :D .
I suspect either bending up the ears of the bottom cork plate, or possibly the kickstart spring being the wrong way round :oops:
Thanks for all your help :wink:
Angry Bloke
All's well that end's well.
You on the road now Paul or does it need registering ?
dapper
storkfoot wrote:Other than it definitely not being the cable adjustment, or reach of the lever, I'm not sure what it was in the end, but I now have an operational clutch :D .
God I feel smug :oops: :oops: :D ;)
storkfoot
Angry Bloke wrote:You on the road now Paul or does it need registering ?
Peachy, Just need a disc brake caliper from CS, which I'll be ordering tomorrow, a hole in the panel, and a bit of a fettle with leaning the carb at the bottom end, and then I'll be booking in a pre-registration MOT :fb:
