Page 2 of 4
Re: exhaust Wrap...
Posted: Tue Feb 22, 2011 2:18 pm
by sydduckett
saigonmark wrote:I wrapped my NK race on my RB20 mainly to get the noise down but also for the looks. It's almost halved the exhaust note and gives it a kind of deep muffled sound. I found the stainless ties provided were not very good so I secured it with stainless jubilee clips.
This is what I used but I manged to get a 30m roll quite cheap off of eBay.
http://www.thermalvelocity.co.uk/Exhaus ... p-105-408/
I can post some pics if anyone is interested.
Mark, could you post some pics. My only concerns were that it would get very dirty/tatty from the weather, not something you need to worry about i guess...
and whether it would rot out the pipe by trapping water? Im hoping it has the opposite effect...
Did you use the carbon fibre look one in your link and did you spray it with silicone after?
Ta
Re: exhaust Wrap...
Posted: Tue Feb 22, 2011 8:05 pm
by soullad
why not spray the wrap with that ACF 50 stuff.
you'll wear out the bearings / rings / seals / clutch plates / reed petals etc etc before you need to worry about the exhaust.
Job done.
Re: exhaust Wrap...
Posted: Wed Feb 23, 2011 11:14 pm
by sydduckett
soullad wrote:why not spray the wrap with that ACF 50 stuff.
Job done.
its not heat proof i believe...?
Re: exhaust Wrap...
Posted: Thu Feb 24, 2011 2:38 am
by saigonmark
sydduckett wrote:saigonmark wrote:I wrapped my NK race on my RB20 mainly to get the noise down but also for the looks. It's almost halved the exhaust note and gives it a kind of deep muffled sound. I found the stainless ties provided were not very good so I secured it with stainless jubilee clips.
Ta
Syd, yes I used the carbon look because they say it doesn't need sealing with the silicone spray (I bought it last summer in England so would not be able to carry the spray back here on the flight without getting arrested ..lol). With the weather back home I would have thought sealing it would be better which means you can use the cheaper non carbon look stuff. We do get a lot of rain here in the wet season but the ambient temp is such that it dries up very quickly.
I've just moved house so the scoot is still parked up at the last place but I should be getting it this w/e so I'll get some pics put up.
Re: exhaust Wrap...
Posted: Sun Feb 27, 2011 4:37 pm
by saigonmark
Re: exhaust Wrap...
Posted: Sun Feb 27, 2011 7:35 pm
by red ghost
When you say 'moved house', you meant mansion right?
Re: exhaust Wrap...
Posted: Sun Feb 27, 2011 10:20 pm
by sydduckett
Cheers mark, i like the look even if it does get a bit dirty over time. Think i may go for the black wrap...
Re: exhaust Wrap...
Posted: Mon Feb 28, 2011 7:14 am
by saigonmark
red ghost wrote:When you say 'moved house', you meant mansion right?
Ha ha...the good thing about big houses is that you can keep your bike inside. A necessity over here as it's a nation of thieving scum, still I think it makes a nice ornament under the stairs...LOL
One thing is that when you fit the wrap it's better you wear some sort of face mask as the fibers are small (like loft insulation) and it irritates when you breath it in. You should wear gloves too but it's impossible to wrap it whilst wearing gloves. I soaked mine in water first to keep the fibers down.
Re: exhaust Wrap...
Posted: Tue Mar 08, 2011 10:42 am
by madmaex08
there are many different wraps on the market. the best by far IMHO is from thermo-tec. i use the graphite black one on both of my TS1 machines.
http://www.thermotec.com/products/11021 ... black.html
for rustprotection underneath the wrap i use VHT paint
http://www.vhtpaint.com/flameproof.html this is the most heat resistant paint i found so far. its even available in a multitude of colors as well as in clear! in fact i use it on all my exhausts.
as already mentioned, dip the wrap in water first, wear gloves and a breathing mask - this stuff is aggressive on your skin and lungs.
do not wrap the exhaust in 1 go because then it is possible for the wrap to come loose. always go from thin to thick, this way you get a tight fit. 2 seperate sections that meet at the exhaustmount should do the trick. stainless jubilee is a good idea od course.
i have ridden my first wrap around 3.500km last year. it certainly did what i wanted it to do - dampen the banshee sound of my fat mamba. as long as you don´t go swimming with it, the heat of the exhaust will dry it up in notime. sofar no problems with rust at all. also with the kinda black wrap it really doesn´t look dirty - i like the look a lot.
will post a couple pics later if you are interested.
Re: exhaust Wrap...
Posted: Tue Mar 08, 2011 2:20 pm
by sydduckett
madmaex08 wrote:there are many different wraps on the market. the best by far IMHO is from thermo-tec. i use the graphite black one on both of my TS1 machines.
Some pics would be great. When you say "from thin to thick" do you mean you start from the stub end, wrap up until just before where the main exhast bracket fits to the case. Then start from the end can end and meet up with the first wrap? Hope that made sense.....
Ps did you bother proofing it after you had put it on?
ta.
