Re: kickstart stops dead/meets resistence at begining of str
Posted: Tue Feb 15, 2011 10:39 am
Some will tell you to fit a thinner top plate, but that makes no difference as both thick and thin top plate are retained by the circlip, as the position of the circlip is unchanged then both will sit at the same height.
Sometimes changing the spider helps as this is what position the clip and top plate.
The cut away pics of the clutch are Excellent.
