Page 2 of 9
Re: TV175 Series 3 -62, restoration
Posted: Fri Dec 03, 2010 12:09 am
by carlos fandango
kejj wrote:Are original bolts so hard to take off? Maybe it's because the bike hasn't been runned for ages!
Not inside the engine it shouldn't. ive never had much problem with the front sprocket bolt.
Posted: Fri Dec 03, 2010 1:11 pm
by kejj
carlos fandango wrote:kejj wrote:Are original bolts so hard to take off? Maybe it's because the bike hasn't been runned for ages!
Success, It's now removed, a compressor air driven socket impact gun did the job for me.
It just needed a little more power.
Now to that clutch arm circlip I cant get a hold on with my circlip removers!
Posted: Sat Jan 08, 2011 7:18 pm
by kejj
More updates on the restore. Christmas and new years leaves the garage empty and al alone!
Some images on the electrics and posts on the blog.
http://tv175.wordpress.com/2011/01/06/electrics/
Posted: Mon Jan 10, 2011 10:12 am
by kejj
Updated info on the restoration. I have reached the clutch and gears.
There is a considerable amount of wear on the clutch spider and rear sprocket from the clutch plates hitting on it. the pressure plate is fine. The gears seem to be in a very good condition. Or i don't know what I'm looking at since it's all first time. The chain has a great tension still but I've found some broken links on it so it goes to the bin.
Read more and view images here:
http://tv175.wordpress.com/2011/01/10/g ... nd-clutch/
Posted: Mon Jan 10, 2011 2:40 pm
by kejj
It's piston time!
anyone recognize? Borgo 62,4 64533/6.
Complete blogg:
http://tv175.wordpress.com/2011/01/10/piston-clean/
Posted: Tue Jan 11, 2011 10:01 am
by kejj
After viewing the scooterrestorations website I realise this is a 2nd oversized piston. So, is the engine rebored or could it be that way original?
"For 2nd oversize TV175 Series 2 & 3 models. Comes with cast iron piston rings (3 ring set), 2 x circlips and Gudgeon Pin. Made in Italy by Borgo, original suppliers to Innocenti (new old stock)"
http://tinyurl.com/63b5zky
Posted: Tue Jan 11, 2011 5:14 pm
by psychedelicropcircle
its hard to tell from the photos with regards to your rear sprocket...if you do change, make sure its a one piece.....i.e not riveted together, as for the gear box it does look to be in good condition...most of em do...if the piston is the 1st oversize then its been rebored once....keep em coming finishing up my S1 THEN ITS s3 tv time
by kejj
And it's Layshaft time!
I have removed the layshaft. It seems to bee in good condition. The only part with considerable wear is the gear selector sliding dog. Strangely enough I didn’t see any damages or wear on the gears themselves. I have read on internet forums that old layshafts have finally given up but I’ll hope that since this bike hasn’t been run for 24 years it’s layshaft will still have some life left for a couple of years.
TV175 Series 3 1962: Layshaft
Posted: Tue Jan 11, 2011 5:18 pm
by kejj
psychedelicropcircle wrote:its hard to tell from the photos with regards to your rear sprocket...if you do change, make sure its a one piece.....i.e not riveted together, as for the gear box it does look to be in good condition...most of em do...if the piston is the 1st oversize then its been rebored once....keep em coming finishing up my S1 THEN ITS s3 tv time
I will try to take some better photos of it later today. Yepp, according to scooterrestoration the 62.4 is on 1st oversize. I will hone the cylinder and try to measure the piston play to find out if it's been worn or in good shape.
Posted: Thu Jan 13, 2011 8:45 am
by kejj
I have come to the stage of cleaning the top end and barrel.
It was a lot of grease that needed degreasing and it took me awhile.
Here are some images of the end result. I got rid of most of
the dirt build up from the top end inside, just some minor left.
Wordpress TV175 blog
