Re: Grade/ thickness of wire to make a new loom
Posted: Tue Jul 26, 2011 10:20 pm
oh yeah diddnt read it proper :freak:
Look at the specification, it is 2.5mm diametre but only 6amp or 10amp commercial rating. The thin wall cable from Vehicle wiring products is 2.1mm diameter but 16.5 amp rating! Even though the strand make up is identical (32 x 0.2mm) the rating is different, this will down to the grade of conductor and insulation.RICSPEED wrote:i would have thought 0.6 to be a little thineden wrote:soulsurfer wrote: http://www.maplin.co.uk/equipment-wire- ... lWin111003
I cant see how much wire you getis it for 10 meters?
It will be negligible, because the HT current is minuscule.RICSPEED wrote:while on the subject of resistance ...is a short ht lead better than a long one ? or is the difference negligible ??
