Page 2 of 2
Re: how to make a DL 125 faster
Posted: Tue Nov 09, 2010 9:16 pm
by sean brady scooters
Posted: Tue Nov 09, 2010 9:51 pm
by soosh
1960split wrote:thanks for the replies
as for how fast i want to go
i want to get it sorted so i can ride at about 55MPH to keep up with modern traffic
i dont want to mess with it too much as it starts 2nd kick everytime and runs nice just seems to run out of steam in 4th gear
is it worth checking the jetting to see if this is correct
i was told it had a 150 top end put on it but cant confirm this
thanks for your help
Mate,there are still dealers that sell good iron 175 kits that will bolt straight on and you can still run the 20mm carb,up gearing to 5.2 and run an AF bigbore.Not an expensive conversion and it sounds like all you need.Will be reliable if setup good like any engine.
Posted: Wed Nov 10, 2010 11:06 pm
by 1960split
soosh wrote: Mate,there are still dealers that sell good iron 175 kits that will bolt straight on and you can still run the 20mm carb,up gearing to 5.2 and run an AF bigbore.Not an expensive conversion and it sounds like all you need.Will be reliable if setup good like any engine.
like this ?
http://lambretta.co.uk/catalog/product_ ... ts_id=3357
Posted: Thu Nov 11, 2010 5:59 pm
by soosh
like this ?
Exactly. Even AF sell a cheap stage 4 175 kit (i think).You can even still use your standard pipe if you really want to keep the cost down and still be better than what you have.
Posted: Mon Nov 15, 2010 4:05 pm
by lee b
tried getting an af one from them a bit ago,said they dont do 'em anymore and they dont know when or if they are gonna do 'em again.
