Page 2 of 4
Re: Can I use this to run a spotlight?
Posted: Tue Nov 02, 2010 11:24 pm
by Knowledge
This is the spot light that Martin mentions in his first post on this thread.
As he says, it is rated at 9w and is amazingly bright. At 9W, it would consume 1Ah in 1 hour 20minutes. So a 3.2Ah battery would last over 4 hours between recharges. However, you will not see THAT sort of life out of the one on the MB site, as I doubt if that is rated as 0.5Ah (and it has really cheap terminals on the end of the wires).
If you want to check out batteries, visit the Yuasa website. The download files gives you all the info you should ever need.
http://www.lucasbatteryshop.co.uk/data- ... ds-4-w.asp
I have my own plans for this spotlight, on a full DC system.
Posted: Tue Nov 02, 2010 11:49 pm
by Ian Hepworth
Knowledge wrote: However, you will not see THAT sort of life out of the one on the MB site, as I doubt if that is rated as 0.5Ah (and it has really cheap terminals on the end of the wires).
The battery on the MB site is rated as 3700 mAh. I just looked it up and amended the website information. Hope that helps.
Posted: Tue Nov 02, 2010 11:52 pm
by Knowledge
Thanks Ian. So the battery is 0.37Ah, so it would power the 9W light for about 15mins.
Posted: Tue Nov 02, 2010 11:57 pm
by Ian Hepworth
Knowledge wrote:Thanks Ian. So the battery is 0.37Ah, so it would power the 9W light for about 15mins.
It's 3.7Ah, You cocked up on the decimal point. I'm glad you aren't a pharmacist or a nurse in kids intensive care.
http://www.drbattery.com/learning_center.aspx
What is Capacity (mAh)?
The capacity of a battery is rated in mAh or Ah. If the capacity of a battery is 4400mAh (Milli-Amp Hour), it means that this battery can deliver 4400 mA (Milli-Amps) of current for 1 hour at the rated voltage. The actual amount of current a notebook draws depends on the usage. Things like LCD brightness, processor usage and hard drive usage affects the amount of current required.
To convert mAh to Ah, divide by 1000. To convert Ah to mAh, multiply by 1000. 4400mAh = 4.4Ah
Posted: Wed Nov 03, 2010 12:01 am
by coaster
3.7 amps per hour, it's bigger than I thought..
Posted: Wed Nov 03, 2010 12:53 am
by Knowledge
coaster wrote:3.7 amps per hour, it's bigger than I thought..
Or 3.7hours at 1 amp, which frankly, is incredible, especially as this appears to be 10 x 1.2v rechargeable AA dry-cells. It has more power than a sealed lead-acid battery with the dimensions of 134mm x 67mm x 64mm. I am surprised that a battery with such incredible power is fitted with cheap squash terminals, when it should clearly be powering a new electric car.
Anyway, all this discussion might be pointless, as the excellent LED spot light shown above has disappeared from ebay. :(
Posted: Wed Nov 03, 2010 1:21 am
by corrado
sean brady scooters wrote:maybe this would help martin,i think it would really suit you .. :lol:
Oi, we know where you live. :mrgreen:
Posted: Wed Nov 03, 2010 1:29 am
by Train Driver
That's the battery i went for when i had the trailtech vapor, its three years old next year and still going strong, i even forgot to keep it charged last winter and it worked fine after a recharge.
Now if someone could get this to fit
http://www.trailtechproducts.co.uk/acat ... Light.html :bouncing: :bouncing: :bouncing:
Chalkie at replay scooters sorted out a mates problem, he wanted his lambretta to power pathfinder lights when the standard lights were on, power for a garmin 660, powerlet outlet socket for heated clothing etc all sorted with a battery from a electric start vespa
Posted: Wed Nov 03, 2010 10:45 am
by firekdp
Knowledge wrote:Or 3.7hours at 1 amp, which frankly, is incredible(
Yes that would be incredible, but no battery rated at 3700mAh (lead acid or other) could supply 3.7A for an hour. Battery discharge rates aren't as simple as that.
Insulated crimps are also fine as long as they are put on with the correct crimp tool (not the cheap Halfords type), fitted many to military spec control systems and I don't believe there are much higher standards than they demand.
Posted: Wed Nov 03, 2010 11:29 am
by teamsequipe
Train Driver wrote:That's the battery i went for when i had the trailtech vapor, its three years old next year and still going strong, i even forgot to keep it charged last winter and it worked fine after a recharge.
Now, that's worth considering ! Wonder if I could just nail it onto the leggies........ !?
