Re: Indian VIN's?
Posted: Fri Feb 27, 2009 2:29 pm
Is the frame number in the normal place on your frame or is it below the tool box.eibargum wrote:Snap, ive got one as well, made some inquirys and nobodys 100% sure, if you ask 10 people you,ll get 10 ansers. mine, according to the reg docs is an alwyn pushpak, but theres no sign of it ever being one and it had been italianized before i bought it. Mine hasent got the tubes on the subframe were the stand hook bolts go, a local guy that restores lammys told me it may be one of the italian frames that were sent to india when the milan factory wound up, ill make some inquirys on the LCGB site about that one. has yours got the tubes on the subframe, regards.
The Pushpak's I've seen the number is on the frame under the tool box.
But as with everything there doesn't seen to be any hard & fast rule at least not one I can follow.
