Page 2 of 7
Re: sip lambretta speedo
Posted: Fri Oct 22, 2010 7:37 pm
by RICSPEED
yes ..your right ..can just see rpm in the left corner ;)
Posted: Sat Oct 23, 2010 11:27 pm
by sydduckett
DJB wrote:
sydduckett wrote:
Lam46 wrote:Agreed Ric no2 is the best looking IMO..wonder if they will put this into production..? MB one on the market and by all accounts working well now, dactec still being perfected and hopefully this will come to fruition in 2011..
Dont think we will see the dac, trouble at mill... :(
:?: please enlighten us
Heard that the idea had been binned, iv been wainting about 6 months now i guess
Posted: Sat Oct 23, 2010 11:43 pm
by Andy Pickering
Guess its time to get on the MBD waiting list then Sef........ :roll:
Posted: Sun Oct 24, 2010 12:00 am
by sydduckett
Noooooo, its so ugly....Im waiting for the SIP. Do you reckon it will have the magnetic pic up instead of using the speedo cale? bit like puting leaf springs on a modern car...ooops just remebered Ford still do it... :D
Posted: Sun Oct 24, 2010 12:30 pm
by Diablo
Its not as bad as you think regards the cable. It works just like the sensor would on a trailtech.
You input the speedo drive ratio and the circumference of the wheel and it then knows how far the wheel has traveled for each revolution of the cable.
Personally I think the anologue tacho is a clever part of the design which keeps an original look even when the scoot is stationary.
Posted: Sun Oct 24, 2010 12:42 pm
by RICSPEED
analog tacho is a good thing as i like the needle sweep as you rev it :D ...would just mean i would have to find something to put in the pod thing on my toolbox were the tacho is :D
Posted: Sun Oct 24, 2010 7:06 pm
by sydduckett
My understanding after looking at the faces they have shown and after looking at the Vespa ones that they make are:
The sweeping hand is for the speed which can be set for mph or Km (hold a button down for 3 secs?)
The digital readout below is for revs
Runs of a pick up on the hub/rim not traditional cable
Has temp gauge, though noit sure if this is for pipe or plug
Has low fuel warning light (doesnt seem to have room for 1/4, !/2 and full on face?)
Or am i missing somthing... :? I soooo want one of these and for it to work. .. :D
Posted: Sun Oct 24, 2010 7:09 pm
by RICSPEED
sydduckett wrote:My understanding after looking at the faces they have shown and after looking at the Vespa ones that they make are:
if you click the image in the first post to enlarge ...you can just make out ....rpm in the right bottom corner of what would be standard speedo
Posted: Sun Oct 24, 2010 7:33 pm
by Diablo
Speed is shown digitally. The tacho display is anologue and is deliberately designed to mimick a speedo needle. Revs can also be displayed digitally simultaneously.
The temp readout comes with a CHT gauge as standard but a water temp sensor is available as an extra.
I don't think it has a low fuel light.
Posted: Sun Oct 24, 2010 7:37 pm
by soulsurfer
From what I've read...
Sweeping hand is RPM
Digital display shows MPH, total miles, trip miles, clock, time travelled and temp, these are shown when pressing a switch to change display.
Speedo runs off cable, I would assume RPM comes from a lead around the HT lead.
Comes with a plug temp lead to give cylinder head temp.
Don't think it has a fuel light.
EDIT: ^What he said :D
