Torquing up Franspeed stubs
eibargum
soulsurfer wrote:K-nuts have a flange too, they're used in motorsport, the M7 takes an 8mm socket, they also have the benefit of self locking. Available from here ;-)
They look much like the GTS ones Mike, on the GTS ones you need to use a spring washer as they are not self locking, the ones Mike has shown you could well be better.
sydduckett
After taking off the flywheel cowelling and head cowelling and filling a couple of mm of the bottom corner of the mag i was able to get an open ended spanner on it band get them tight. Wouldnt fancy haveing to do it at the side of the road though... :D
