Page 2 of 3
Re: clutch help
Posted: Thu Oct 14, 2010 10:27 pm
by tony
clutches get hot of course.. expand and if you dont have enough slack in the cable this can cause them to slip. usually tho it will continue slipping if this is the case. I'd think it more likely the outer is too short or it caught on something.
Re: clutch help
Posted: Thu Oct 14, 2010 10:29 pm
by mark
when i strip at weekend i will investigate
Re: clutch help
Posted: Thu Oct 14, 2010 10:47 pm
by RICSPEED
mark wrote: "dominic cant be arsed "
thats not good is it :evil:
Re: clutch help
Posted: Fri Oct 15, 2010 12:12 am
by goldeneye
you still after some vespa springs for your motor? pm me your address, i"ll send you some for nowt. ;)
Re: clutch help
Posted: Fri Oct 15, 2010 12:32 am
by byron
Bilko wrote:Just measured them at 2.50 with digi callipers
yep, found them, a smidge over that with old school micrometer...
that jeff's a good bloke, eh ?
Re: clutch help
Posted: Sat Oct 16, 2010 6:51 pm
by mark
Latest update: went out on bike today and it wasn't ticking over evenly so took for a little ride and got to traffic lights and tick over was up to about 4k. Turned round to go home, got about 100 yds and revs went to 8-9k shut ignition of and it kept screaming so I stalled it. Stripped panel of and found a huge crack in my inlet manifold so I'm hoping it isn't a clutch problem but will know more next weekend.
Re: clutch help
Posted: Sat Oct 16, 2010 8:23 pm
by Bilko
Good find Mark. If you know what I mean, could have been a disaster.
Re: clutch help
Posted: Sat Oct 16, 2010 8:59 pm
by mark
Hopefully this is my problem 8-)
Re: clutch help
Posted: Tue Oct 19, 2010 7:56 pm
by mark
latest update . i have found what cracked my manifold ,it was my rear set bracket bolt fouling it and manifold moving against it stressed it. sorting tomorrow
Re: clutch help
Posted: Tue Oct 19, 2010 8:08 pm
by byron
mark wrote:latest update . i have found what cracked my manifold ,it was my rear set bracket bolt fouling it and manifold moving against it stressed it. sorting tomorrow
cool. always good to find the cause of a problem
