Page 2 of 2
Re: New Member Li125 Dying at full throttle
Posted: Tue Oct 05, 2010 10:16 pm
by rog60
I don't suppose it's something stupidly simple like partiallyblocked main jet/atomiser/main jet loose
Posted: Tue Oct 05, 2010 10:18 pm
by Andy Pickering
Or fuel tank cap breather holes blocked..?
Posted: Tue Oct 05, 2010 10:29 pm
by RICSPEED
have been in this situation myself ...scoot would run fine ...untill you gave it full bore ....the tap cannot keep up with the demand for fule from the motor so would just die ...if i shut off it would then take a good few seconds to refill bowl before comming to life again
Posted: Tue Oct 05, 2010 10:39 pm
by jazmanuk
Taking all sugestions on board thanks.
I have had the fuel tap apart and all appears ok, checked fuel running freely into container, this is the original tap and has worked ok in the past. I have also checked the fuel cap breather holes again clear.
The feedback I get when riding at full throttle is that the engine just shuts down without any cough or splutter as if you had hit the cut out button. Up until last week the engine had run with no problems encountered, appears to be something breaking down?
Posted: Tue Oct 05, 2010 11:29 pm
by goldeneye
fit a new fast flow petrol tap. sounds like your old one is goosed.
Posted: Wed Oct 06, 2010 7:35 am
by jazmanuk
ref: fast flow fuel tap, i have one on order as a first try.
Posted: Wed Oct 06, 2010 11:04 am
by westburyst
happened to me yesterday on the way home from work. on 4th gear and engine just died had to coast to the side of the road. was riding fine until that happened. i'm breaking in the motor as i've had the cylinder re-bored. similar symptoms as what jazmanuk has encountered. my fuel cap does not have a hole so i've drilled a 2mm hole. i rode the gp again at night to test it out and seemed ok. i'll test ride again tomorrow and see what happens.
Posted: Tue Oct 12, 2010 12:34 pm
by methleymongo
jazmanuk wrote:Taking all sugestions on board thanks.
check that the slide on the carb is going right down to the bottom, & not leaving a small gap.
