Page 2 of 2
Re: Timing problems
Posted: Mon Sep 27, 2010 7:18 pm
by paulski
paulski wrote:
Magalluf wrote:I have fixed the problew of the points now I have a new problem. If I turn the stator as far as I can to the left it shows about 30º and if I turn it as far as I can to the right it shows about 25º but the firing point should be at 19º so no mater what i do it is out. Any help please as I´m becoming very disillusioned.
Steve (still hot and sunny in Mallorca)
have you marked your t.d.c accurately. ????
when you say it shows 30 degrees, how are you measurig that???
Re: Timing problems
Posted: Tue Sep 28, 2010 8:14 am
by firekdp
Are the points gapped correctly? Too large a gap will advance the timing.
Re: Timing problems
Posted: Tue Sep 28, 2010 8:27 pm
by Magalluf
Decided to try the fag paper trick and it seems to have made a difference, also the points were a bit far apart so now I have it nearly spot on. Thanks to everyone
Steve (Magalluf)
