Timing problems
paulski
paulski wrote:
Magalluf wrote:I have fixed the problew of the points now I have a new problem. If I turn the stator as far as I can to the left it shows about 30º and if I turn it as far as I can to the right it shows about 25º but the firing point should be at 19º so no mater what i do it is out. Any help please as I´m becoming very disillusioned.
Steve (still hot and sunny in Mallorca)
have you marked your t.d.c accurately. ????
when you say it shows 30 degrees, how are you measurig that???
firekdp
Are the points gapped correctly? Too large a gap will advance the timing.
Magalluf
Decided to try the fag paper trick and it seems to have made a difference, also the points were a bit far apart so now I have it nearly spot on. Thanks to everyone
Steve (Magalluf)
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 3 guests
