A Flywheel, a puller and an annoyed person
goldeneye
remove nut, start engine, rev it up, flywheel will come off. stand clear in case it hits next doors vauxhall viva. ;)
sideout
goldeneye wrote:remove nut, start engine, rev it up, flywheel will come off. stand clear in case it hits next doors vauxhall viva. ;)
:lol:......and then it's the front wheel against a wall and drop the clutch in 1st at max revs. As a well known Weymouth scooterist would say... "something will happen" :!: :D :D :D
Bilko
Main scooter: LI150
corrado wrote:Is it possible to drill out the rivets holding the flywheel fan to the boss? Once the fan is off the 3 legged puller should work.
Without checking (In bed) would I not damage the stator plate with the varitronic flywheel?
Bilko's Oily Blog
joespeed
joespeed wrote:now that you have two pullers,cut a slot or two straight through the threads to make it look like a tap try screwing it in,should cut its own thread to a damaged flywheel !
regards
joe
have you tried this method ,it never fails!
Bilko
Main scooter: LI150
regards
joe
Except me. I did try this. Been trying all flippin' day! :oops: :? :shock: :(
Bilko's Oily Blog
KCB
When mine did this I dremmeled a couple of mm of the flywheel to get to a decent bit of thread, pain in the arse but it worked!
Bilko
Main scooter: LI150
Thanks, I'll try that
Bilko's Oily Blog
