Page 2 of 2
Re: Frame Straightening
Posted: Wed Jul 21, 2010 6:44 pm
by Lamaddict
[/quote]
i ment mike maxwell (soulsurfer) not john wayne in manchester :D i also know someone who had a fram and rear struts done there at a cost of over £250 :shock: then primed and dry built one rear strut was so high the floorboards touched the panels even when adjusted to the max i cut the left side floorboard rest off welded the holes on the old one and the new one and we sorted it .........then came the fuel tank fitting probs :roll:[/quote]
I actually held back on how bad the 'repair' was. It was shocking even the parts used to rebuild the forks were unrecognisable and looked to me like like Indian bad pattern tat.
Thanks for the other inputs it sounds like they need to go to a professional place. I'll try CS Engineering.
Posted: Wed Jul 21, 2010 7:30 pm
by soulsurfer
Lamaddict wrote: Thanks for the other inputs it sounds like they need to go to a professional place. I'll try CS Engineering.
Give Shocky a try, the forks in my picture were well out, I took them to a recommended dealer to fix them and they were still the same, Shocky sorted them perfectly ;)
Posted: Thu Jul 22, 2010 12:05 am
by heliscoot
mike phoenix did my frame, made a right knackers of it, pleasant bloke mind!
