Page 2 of 9
Re: SX250LC custom
Posted: Mon Aug 02, 2010 2:39 am
by Ruudboy
Because we are going to paint the flywheel...
But it looks a bit bigger on the picture then it actually is.
Re: SX250LC custom
Posted: Mon Aug 02, 2010 8:02 am
by Ruudboy
The custom rear hub:
Awesome!
Pat's login aint working so i quote: "I’m tempted to make a batch of 10 if there’s interest but they’ll be 275.00quid each plus p+p. Will make them either for standard drum set up or convert as ours to the disc brake set up. Pat"
Re: SX250LC custom
Posted: Mon Aug 02, 2010 9:27 pm
by joespeed
is it sand or pressure cast?
Re: SX250LC custom
Posted: Mon Aug 02, 2010 11:58 pm
by MADSPEEDRB260
Ruudboy wrote:The custom rear hub:
Awesome!
8-) ILL HAVE ONE GIVE US A BELL 07884075408
Re: SX250LC custom
Posted: Tue Aug 03, 2010 12:20 am
by Wayne Miller
joespeed wrote:is it sand or pressure cast?
Hi Joe, he said in an earlier post . . . .
'Custom CNC 6061 T6 Rear Hub to match front hub'
Looks like its machined from a lump of ally :-)
Re: SX250LC custom
Posted: Tue Aug 03, 2010 5:13 am
by Ruudboy
Yes it is cnc'd from a big lump of 6061 T6 (http://en.wikipedia.org/wiki/6061_aluminium_alloy)! Thats why its not cheap!
You can contact pat at [email protected] i guess he will make a list and if there is enough potential he will do a small run of 10.
Re: SX250LC custom
Posted: Tue Aug 03, 2010 7:42 am
by mark
email sent ,heres hoping
Re: SX250LC custom
Posted: Tue Aug 03, 2010 11:08 pm
by Knowledge
Ruudboy wrote:Because we are going to paint the flywheel...
Even if it is not as big as it looks in the picture, I still think you will have a problem with the air rolling off the end of the fins of the fan (cavitating) before it can be pushed over the cylinder. The design of the standard fan cover is for a reason.
Re: SX250LC custom
Posted: Wed Aug 04, 2010 2:52 am
by Ruudboy
Well we only removed the inner circles (which are open anyway) but interesting point. Could always add some custom wording like done on many other bikes before.
Re: SX250LC custom
Posted: Thu Aug 05, 2010 7:27 pm
by Rich_T
On your hub you might want to double up on the disc fixings from 3 to 6. It looks like you have 3 x M8 bolts in sheer on quite a small PCD. For the sake of 3 more fixings I'd double up, hubs, rims and break parts always make me nervous, a disc parting company with the hub assembly would be a nasty one.
