Page 2 of 2
Re: New Race tour piston gone for a burton
Posted: Thu Jun 24, 2010 6:46 pm
by clubbook
Sorry drunkmunkey thought i'd posted carb settings. Not sure where they,ve gone!
Current settings with TS1 are
Needle - 5 EL68.3
Needle jet - not sure but one recommended by Chiselspeed for spec
Pilot 27.5
Main jet - now up to 350
Power jet - blanked off
Ram air filter
Posted: Thu Jun 24, 2010 6:56 pm
by clubbook
drunkmunkey6969 wrote:
clubbook wrote:Recently siezed my modified/tuned cast barrel with new MB race tour piston (ouch!) at about 45 to 50 mph, (this was after 300 or 400 miles) at reasonably high speed with no problems.
So........main jet cools efficienntly at wide open throttle, you have done 300-400 miles at high speed with no problems......but in the mid range 45-50mph (so 4000rpm-5000rpm??) it seizes.........as i say.......what are the rest of your carb settings?
Needle - 5 EL68.3
Pilot 27.5
Ram air filter
Posted: Thu Jun 24, 2010 10:48 pm
by soullad
listen to yer Uncle Dan, jet for the whole of your throttle openings. And then check for air leaks?
Posted: Fri Jun 25, 2010 11:23 am
by drunkmunkey6969
what clip was needle on?
Posted: Fri Jun 25, 2010 1:27 pm
by clubbook
Was middle now second from bottom
Posted: Fri Jun 25, 2010 2:05 pm
by drunkmunkey6969
clubbook wrote:Was middle now second from bottom
And did that make it any boggier, or does it still pull OK?
Posted: Fri Jun 25, 2010 4:59 pm
by Dryballs
Wow - those settings are richer than my TS1 with the same carb
I'd be looking for an air leak or ignition fault first of all.
Maybe take off your barrel and mag flange and just make sure everything looks OK. Maybe change your gearbox side oil seal while youre at it
Cheers,
db
Posted: Fri Jun 25, 2010 5:08 pm
by drunkmunkey6969
Try a plug chop at WOT and same again at 1/2 throttle, i'd be interested to know if the new clip setting has cured your problem.
Also, you may have gone too heavy on the main jet whilst rying to compensate for a midrange lean spot, and if richening up the midrange has cured any lean spots, you may be able to come back down on the main. As DB says....your other settings sound very rich (both main and pilot).
If it is an air leak issue, oil seal leaks may show up as heavy white smoke from exhaust can, rough running and inability to tickover properly......place palm of your hand about 4 inches from end of can and rev scooter.....does it splatter oil all over your hand, is it bellowing smoke?
Oil seal failures/wear is quite common, when were they changed last?
Let us know how you get on.
Posted: Fri Jun 25, 2010 8:15 pm
by clubbook
Made it a little boggier
Posted: Fri Jun 25, 2010 8:50 pm
by clubbook
drunkmunkey6969 wrote:Try a plug chop at WOT and same again at 1/2 throttle, i'd be interested to know if the new clip setting has cured your problem.
No heavy smoking, runs really well and ticks over perfect!
Oils seals change last week, and 2 weeks before that following sieze of cast barrell. Using red double lipped Viton seals.
Have stripped engine today to find oil seals still in good condition, but gearbox oil in barrel. No cracks to casing or visible damage. But have found a discrepancy with thickness and depth of indian (SIL) gear side back plate which we think could be holding the oil seal at the wrong height. Changing this for MB one and see what happens!!
Paul
