Re: what ever happened to the new super monza
Posted: Mon Jul 12, 2010 9:56 pm
Like I said OUCH...soulsurfer wrote:725€ plus 670€ for the pipe.
£607.28 £561.21...still expensive..GP240 wrote:anybody told him it's not two euro to the pound now?
That has to be a titanium pipe, for that price. That's good news if it kicks off other dealers making pipes from titanium. Obviously not good for the dealers who make pipes that fall to bits every year, and need replacing..soulsurfer wrote: 725€ plus 670€ for the pipe.
Only people that are too lazy to set it up right, surely?J1MS wrote: How many have spent on an engine that promised to be good, and blew it up when ridden to a rally then costing nearly as much to rebuild as the original did ?
or unavoidable reasons like knackered base gasket, knackered exhaust gasket, split carb rubber , dodgy fuel, blocked breather ,blocked petrol tap, circlip poping out ,chain guide snapping ................................ cracked pipe ,magnet in flywheel coming loose ,race crank that twists, stone in carb, read petel screw comes loose i gave up letting other build my enginesMuttley McLadd wrote:That has to be a titanium pipe, for that price. That's good news if it kicks off other dealers making pipes from titanium. Obviously not good for the dealers who make pipes that fall to bits every year, and need replacing..soulsurfer wrote: 725€ plus 670€ for the pipe.
Blimey... never heard of that before.shocky wrote: Or, unavoidable reasons like knackered base gasket, knackered exhaust gasket, split carb rubber , dodgy fuel, blocked breather, blocked petrol tap, circlip poping ou, chain guide snapping, cracked pipe, magnet in flywheel coming loose, race crank that twists, stone in carb, read petel screw came loose. I gave up letting others build my engines.
soulsurfer wrote: The piston is a very good italian made cast one with 2 good rings that can withstand wider exhaust ports than normal rings you have in the TS-1. "
How come it's for sale on LTH but not on CamLam???giankx wrote:Here you are.....
http://www.lambretta-teile.de/Zylinderk ... l200-SX200
http://www.lambretta-teile.de/Auspuff-S ... -Lambretta
