Page 2 of 2
Re: rapido 250 with 62 stroke
Posted: Wed Jun 16, 2010 5:14 pm
by mickdale
as knowledge says + he is going for ceramic lining as opposed to nicasil and is using his "own type piston" aswell - piston will apparently be competatively priced
Posted: Fri Jun 18, 2010 1:20 pm
by Dimitrios_231
Does anyone know,
if the larger port timing can affect a rapid throttle closing.
For example,
in 3rd or 4th gear and having enough revs, you close the throttle to let the lammy roll.
What will happen to the gases when the port timing is larger?
