Page 2 of 2
Re: Casa 185 kit
Posted: Mon May 31, 2010 6:55 am
by minotaur
you should avoid 2 up for a bit, i use a sito ancillotti exhaust and seems good to me
Re: Casa 185 kit
Posted: Mon May 31, 2010 11:01 pm
by TS1-200
An ordinary AF Clubman works well. no need to spend more money on expansions or the "improved" clubmans
Re: Casa 185 kit
Posted: Mon May 31, 2010 11:44 pm
by Funkspeed
As a matter of interest what carbs/jets are folk running on these? I'm not sure about the jetting in mine but at the moment running a 20mm Delorto running through the airbox.
Even though kit only recently fitted it does seem a bit "strangled".
Re: Casa 185 kit
Posted: Tue Jun 01, 2010 7:20 am
by minotaur
i run a 24mm PWK through a ram air filter, and a lightened flywheel
Re: Casa 185 kit
Posted: Tue Jun 01, 2010 11:13 am
by Stokie
Has anyone done a port map of this kit that they can post or know the port timings ?
Re: Casa 185 kit
Posted: Tue Jun 01, 2010 11:18 am
by L4Lambretta
Hope you don't mind me hijacking this forum; Minotaur, what jetting are you using. Have the same carb and casa kit, and finally some time to put it all together. Think I'll use a Gp air box.
Re: Casa 185 kit
Posted: Tue Jun 01, 2010 2:02 pm
by minotaur
i'll take off carb tomorrow and check as i'm fitting a powerjet anyway, and will then need to re-jet, i will let you know
Re: Casa 185 kit
Posted: Tue Jun 08, 2010 9:16 pm
by Funkspeed
Now found out that motor has already been run in.
Think I'll be changing from the standard carb 22 mm through airbox to a 24mm or 26mm.
I'll be looking at a decent exhaust too.
Any recommendations at all to get the best out of this kit as seems quite sluggish at the moment?
Re: Casa 185 kit
Posted: Sun Jun 13, 2010 3:16 pm
by minotaur
i've, just fitted an oko pwk with built in power jet i found on ebay germany, 36 pilot , needle 2nd clip 112 main, ram air remote and sito ancilloti exhaust , gp 200 gearing, the pwk with powerjet is a differnt proposition to the normal one, lovely to ride, smooth even power from t. over to w.o.t, not a blip thru the range
